Gtx 1050 4gb
Gtx 1050 4gb
Message 1 of 15
Gtx 1050 4gb
I've bought a new portable pc with:
4k
32 gb ram DDR4
Intel i7-7700HQ
nvidia Gtx 1050 with 4gb dedicated.
There is a problem with the nvidia gtx, like a patch that i can't found. I use autocad 2018.
Somewhone can help me?
Replies (14)
Message 2 of 15
-FDC-
Did you install the latest autocad (2018.1.1)
The latest nvidia drivers.
The latest windows updates
And very important the latest .NET Framework version?
Is it windows 10 you're on?
Message 3 of 15
Yes, I've tried everything.
We should find a edit internal video driver for Gtx1050, or a memory location management....
Message 4 of 15
-FDC-
Maybe the latest driver isn't compatible with autocad.
Try this link.
Fill in your specs and download the recommended driver.
http://usa.autodesk.com/adsk/servlet/syscert?siteID=123112&id=18844534
Message 5 of 15
-FDC-
Or you can try the command "graphicsconfig" and disable Hardware acceleration.
Message 6 of 15
There isn't my Nvidia Gtx 1050
Message 7 of 15
-FDC-
Then try with disabling hardware acceleration.
Message 8 of 15
If doesn't work?
Message 9 of 15
-FDC-
Try to deinstall the nvidia drivers and see if autocad runs without the drivers.
Message 10 of 15
Alfred.NESWADBA
Did I miss something? You wrote "there is a problem" ... but I have not found which problem you have.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Message 11 of 15
Autocad doesn't read the nvidia, and, nvidia doesn't work with autocad, there isn't a correct driver
Message 12 of 15
-FDC-
Yes but what is autocad telling you?
What kind of error does it say?
Maybe a screenshot could help.
Message 13 of 15
Alfred.NESWADBA
Please start command _GRAPHICSINFO and show us the screenshot
Also please start command _ABOUT and show us the screenshot.
Here are some AKN articles showing info about "AutoCAD does not recognize the nVidia card:
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/sfdcarticles/sfdcarticles/AutoCAD-...
https://knowledge.autodesk.com/support/infraworks/troubleshooting/caas/sfdcarticles/sfdcarticles/How...
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/AutoCA...
HTH, - alfred -
Alfred NESWADBA
Message 14 of 15
I have the same problem.
I can not use hardware acceleration in autocad 2018 and without that drawing in autocad is very difficult, especially when using the polyline.
Sometimes the laptop is frozen if actived the graphics aceleration and other times the bluescreen is appears.
I have a laptop asus rog gl553vd with a gtx 1050
Message 15 of 15
pendean
Community Legend
Community Legend
Unless it is only you with many posts in these forums, there appears to be many issues with Asus Laptops crashing/freezing in AutoCAD in the last two days.
Was there an Asus sale last week or earlier this month? Or you all from the same school and bought these laptops from school?
