Grid Lines not showing in Model Space even after clicking button on the status bar.
jacqueline.hickey
Observer Observer
Message 1 of 9
jacqueline.hickey
Observer
Observer
Upon opening a saved AutoCad file, I did not see the gridlines in the Model Space. I clicked on the button in the status bar, but the lines are still not showing. Is there another configuration for this? Thanks so much for your help~!
Replies (8)
Message 2 of 9
cadffm
Check your LIMITEN
and GRID limiten setting.
https://help.autodesk.com/view/ACD/2021/ENU/?guid=GUID-7EC38AD6-FA34-4115-9E1C-6F13E1BA033D
Sebastian
Message 3 of 9
user181
What is your GRIDDISPLAY variable set to?  Try setting it at 3.
Message 4 of 9
Kent1Cooper
Are there dots instead?  Look into the GRIDSTYLE System Variable.
Is the grid spacing too large for your view area?  Look into the GRIDUNIT System Variable.
For that matter, just look through all the System Variables that start with GRID, >here<.
Kent Cooper, AIA
Message 5 of 9
Valentin_CAD
@jacqueline.hickey ,
"In certain AutoCAD drawings (DWG files), the background grid will not display using F7, GRIDMODE = 1, or by toggling the status bar icon."
Solution:
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
Message 6 of 9
dstewardEGNTS
I suspect that your grid colors under option and display tab and colors button are the same color as your background. so when they are on the still do not appear.
Message 7 of 9
dstewardEGNTS
you can fix it by restoring defaults
Message 8 of 9
Valentin_CAD
No need to restore to default, just do as the link mentions:
Emilio Valentin
Message 9 of 9
sharpl
Thank you, you never miss the mark @Kent1Cooper
