First time posting, very new to autocad.
Working through some college work at home, and when I download + open my drawings + template the area around the viewport is now grey when it was white. This is my first time using Cad on this Pc.
Also the templates seemed to have been moved around as seen in the second image
Run command: PLOT
Compare Printer/Plotter you see at school vs what you see at home:
It's fine until you need to PLOT. That's when you'll need to make sure it looks right.
Oh right, , Im just unsure of which way to have the page set up. I dont think that they're actually being printed it says on the marking rubric that the drawings should be to an interational standard.
if no printing or pdf creation is required, then you're good to go.
Hi @dylan051
<<the area around the viewport is now grey>>
The gray area is the default appearance. The white area represents a hardcopy of your A4 sheet and the gray represents the desktop your sheet sits on.
<<templates seemed to have been moved around>>
You can re-center your template like this=>Click Apply=>Click Preview.
