grey lines dont want to go away
JJ.nieuwoudt_Zutari
JJ.nieuwoudt_Zutari
Community Visitor
Community Visitor
hi guys
who can help me with this it only appears in layout view and you cant select the grey lines or delete. If you zoom out the grey lines just go on and on grey.JPG the lines?
imadHabash
would you please attache here your dwg file for testing ? BUT you can - as a start - try AUDIT and PURGE ( reg ) commands and see if any changes .
Imad Habash
Corsten.Au
HI
Those grey lines may be XLINE, extended infinitely..
select and delete them..
if you cannot delete then check the layers they are in...if the layer is locked..unlock and delete those lines..
Cheers!
Corsten
Building Designer
Alfred.NESWADBA
Try command _GRAPHICSCONFIG and turn off hardware acceleration ... better?
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
