Grey box around object and unable to edit
I received a .dwg file form a customer that had been converted from CADWorx Plant. I can open the file easily. When I click on an object such as the pipe shown in the picture it does not allow me to edit or move the piece. Any ways around this?
Thanks.
cheryl.buck
Autodesk Support
Autodesk Support
Hi @Anonymous,
Welcome to the Autodesk Forums!
Thank you for the screen shot. Without the DWG file, its a little hard to tell exactly what is happening, but generally speaking, third party objects are brought in as Proxy objects, to edit these objects, the original application may be required, see below for more information.
About Custom Objects and Proxy Objects | AutoCAD
You could try to do an EXPORTTOAUTOCAD which will convert all the objects, that AutoCAD is able to do so with, to AutoCAD recognized format.
Let us know if this helps.
Please click the Accept Solution button on any posts that resolve the problem or answer your question.
Likes are always welcome.
All the best,
Cheryl Buck
Technical Support Specialist
Did a post answer your question or help resolve the issue? Please click the Accept Solution button.
If you find a response helpful, consider Liking the post.
I have attached the file.
It is a proxy entity GROUP.  I was able to UNGROUP it then EXPLODE one of the items into lines and circles.  May take a few explodes to get it done. Or Explode them all.
