graphical scale 3/32" = 1'-0"
i need to show a graphical scale on autocad for 3/32" = 1'-0" for a drawing. how do I make one and I need to make sure its accurate.
attached is the drawing. at the bottom of the pages for the first, second and basement floors, there is a graphical scale. when I print that out on full size paper (D-size), and when I measure it since its 3/32" = 1'-0", it should measure to three inches I assume, is that correct? if anyone could reply back to this that would be much appreciated. thanks.
ChicagoLooper
Either choose the 3/32" = 1'-0" scale shown in the list. If it's not in the list then you'll need to create it from scratch. It will look like this.
Chicagolooper
yes I know how to do that. but that's not what im asking for. if you see the second message I put on here, that's what I need
ChicagoLooper
Yes. While in paperspace, 3" should equal 32'-0". The scale bar shown on the PDF however, is only 2.75" (see below).
To test, draw a rectangle in paperspace. Make it 3 inches wide and 1 inch tall. Select the rect. Then CHSPACE command. Got to modelspace and measure that rect.
Chicagolooper
thank you that is very helpful.
gstein
When you are inside the model space view just type: ZOOM 1/256XP
That sets your view zoom to 1 / 256 times the Paper Space.
