Dear Forum,
I have encountered a rather peculiar problem which never happened to me before. I am usually drawing floor plans and sections based on ReCap point cloud. I imported points from a *.txt file with a size of 180MB. When drawing with the point cloud attached, it's really hard to handle even basic functions like strech, extend, fillet, etc. When zooming in and out at a normal scale, my vector drawing starts 'shaking' up and down left to the right....My splines are not at all smooth. I attached a couple of screenshots. Any suggestions are welcome. I am using AutoCAD 2016. Thank you!!
try to set your VIEWRES to 20000 and untick hardware accelerations from options and see if helps. thanks
Thank you for your answer.Unfortunately, the problem persists. Moreover, I cannot disable the Hardware Accelation because I am using an *RCP pointcloud.
Still looking for a solution.
Paulina
