Can anyone help me out with this issue? While I plot this viewport the main wall doesn't show (you can see inner ribs of the wall in plot) but if I rotate the view by little and plot it, will show.
does the same happened if you make a new Viewport for the same area ?
Imad Habash
Yeah I've tried with that, it still doesn't show, but the plotted Isometric view don't have that issue.
I added a rectangular box @ front wall (3/4 inch far from Main wall), surprisingly it worked but still I would prefer better solution. I'm assuming it gotta be some Graphical issue.
Which visual style have you assigned this viewport?
If it's hidden, how big is the distance between the wall and the objects behind the wall (which are hidden on display, but visible on plot).
You might also try to select the viewport, and change the property "Shade Plot" to "Legacy hidden" ... better?
If nothing helps then please upload this dwg-file so we can see all your settings instead of guessing...
- alfred -
