GPU problem (little to no usage)
So I'm a student and I'm currently working on a project, and my desktop at home won't use my GPU when I start to render or even just look at the drawing (In some instances it uses just 20% for a split second but only when I'm just viewing the drawing). I've already searched for some answers and tried a bunch of things. In one post they discussed the same problem and they fixed it by excluding the AutoCAD folder from the system antivirus. So I've tried it and it did not help at all. (https://forums.autodesk.com/t5/autocad-forum/autocad2020-using-to-much-cpu-amp-no-gpu/m-p/9330316).
GPU: Nvidia GeForce RTX 2060 14 GB
RAM: 16GB at 3200MHz
CPU: Intel i5 9400F base 2.9GHz Throttle 4.1 GHz
Thank you for your time.
