Global width axis of Pline in AutoCAD
Hello, Community!.
I have a problem about global width axis.
When I set to some global width value on my pline, Pline of width will be created to vertical, not horizontal.
So, When I move to Top view, I can see the line such as "global width2.JPG(I attach it).
Can I rotate line axis?.
I don't know that line has axis.
I attach image my problem for reference.
@Anonymous,
john.vellek has edited your subject line for clarity: Global width axis.
Alfred.NESWADBA
a polyline is (primary) a 2D-object (as long as it's not a 3D-polyline), and the global-width only is a width, but not a height.
If you want to control the "height" of a linear object then look to the "thickness" property:
HTH, - alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
john.vellek
HI @Anonymous,
Did @Alfred.NESWADBA's excxellent answer help you to understand the Width property on 2d Plines? Please add a post if you need additional information or if you to want to add a sample drawing.
John Vellek
