GIS coordinate system problem.
vzaharief
vzaharief
I am using Аutocad 2024, and I have the following problem. There are no coordinate systems in the geographical location menu. I don't know if I should install them as a library or add them from somewhere. I appreciate any help. Thanks in advance!
Anton_Huizinga
There is no separate install for this, looks like you need to reinstall the software.
vzaharief
Unfortunately, even after reinstallation, this option does not work, the "search for coordinate systems" field is still empty. Any other ideas why this is happening?
Anton_Huizinga
Is there a installation log which describes something? You can find them here:
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Location-of-the-lo...
Maybe you can install Map 3D (part of the toolset) to see if that helps.
pendean
Community Legend
Community Legend
@vzaharief Have you had a chance to reinstall your software yet?
Do you have an active paid subscription, or is this a student/EDU license?
vzaharief
I reinstalled the software but still have the same problem. I have a student license.
TheCADnoob
