Generating Section Plane to Block
Message 1 of 14
Hello Everyone,
Hoping to get some advice or help with an issue with generating a section plane to a block.
After selecting the section plane and the destination ('Insert as new block' and 'Export to a file') I click create and nothing appears. No preview of the block prompting me to place it or a new file when a destination is chosen.
Any recommendations would be greatly appreciated!
Replies (13)
Message 2 of 14
Alfred.NESWADBA
can you please upload the dwg-file?
The screenshots do not show which types of objects you have/...you want to create a section from.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 3 of 14
Hey Alfred,
Please find the attached DWG file
Thanks for the response!
Message 4 of 14
Alfred.NESWADBA
sorry to say, but what I expected ... your geometry is a 2D-geometry.
To create a section view you need to have 3D-geom!
More details: http://help.autodesk.com/view/ACD/2019/ENU/?guid=GUID-3AC2CA12-2085-4782-B66A-7964B73B55EA
- alfred -
Alfred NESWADBA
Message 5 of 14
joseZ9KZ7
I'm also having troubles with the sections.
In my case I would like to make standar section with the following section settings:
- Intersection Boudary: white color, layer 0
- Intersection fill: face solid, color magenta
- Background lines: show yes, hidden line yes, color 204,204,204
Could you please help me out with this? Is any LISP routine for this?
Kind regards
Message 6 of 14
j.palmeL29YX
What doesn't work for you? At which point do you have problems? And which problems?
Demo
Jürgen Palme
Message 7 of 14
joseZ9KZ7
The problem is that instead of select the settings by myself I want to set the default settings as described before.
Then I won't need to click many times later on.
Message 8 of 14
j.palmeL29YX
F1
(Save Section Objects as Tools.)
Jürgen Palme
Message 9 of 14
joseZ9KZ7
I've tried that out several times and it doesn't work.
When I save the section as a tool, the tool doesn't remember the changes even if I try to fix it.
Message 10 of 14
j.palmeL29YX
Here more detailed how I did it.
(If the video doesn't appear wait some minutes until it is finished at the server)
Jürgen Palme
Message 11 of 14
joseZ9KZ7
Thank you very much for your quick responses.
I think it still doesn't work. If you see in your video, in the section of "intersection fill" "show" no. It should be "yes"
For any reason the tool doesn't remember.
Is there anyway to program it with lisp?
Also ... I can't find the structure tool pallete. Do you know how to find it?
kind regards
Message 12 of 14
j.palmeL29YX
Ok, you're right.
I canceled my test when I saw the predefined values in the settings window. But when I finish the command I also don't get the whished result. 😞
Sorry, my mistake ...
Jürgen Palme
Message 13 of 14
joseZ9KZ7
It's all good.
Thank you very much Jürgen.
Message 14 of 14
j.palmeL29YX
I tested it again in ACAD 2016 - here it works well as expected.
Obviously they did some changes (into the wrong direction).
Jürgen Palme
