function f(x)
function f(x)
yakaic
Observer Observer
function f(x)
yakaic
Observer
Observer
Is there a way creating a line that shows a function like "f(x)=x²"? Optimal case is that I can set the start point e.g. at x=-3 and the end point at x=3 so I get the function in that area.
Is there anything like this?
Thanks for help.
Aaron
tramber
You can make a lisp or create a script pleased to Excel to send a spline.
The only thing is to determinate how many points you want 😉
The more you draw, the more precise you are.
TheCADnoob
Check out this article about using Excel to create functions and then pasted in AutoCAD.
https://forums.autodesk.com/t5/autodesk-community-voices/autocad-excel-your-design-with-a-graphing-c...
CADnoob
tramber
(defun c:fun1(/ *osmode* inter a b dis)
  (setq inter 25 a -3 b 3
	dis(/(- b a)(float inter)))
  (setq *osmode*(getvar"osmode"))
  (setvar"osmode"0)
  (command "_pline"(list a (* a a)))
  (repeat inter(command(list(setq a(+ a dis))(* a a))))
  (command)
  (setvar"osmode"*osmode*)
You can easily change inter, a and b.
Load that and run FUN1
leeminardi
@TheCADnoob The link is a nice write up but the command parameters should specify fit points not not control vertices since the explicit function for sine is used.
That is,   spline m f 0,0  not spline m cv 0,0
 Also, when choosing the delta x value for something like a trig function it would be better if the minimum and maximum values were explicitly specified.
As a side note, the attached Excel file includes a custom function I wrote for creating of B-splines from control vertices.  It will duplicate the splines created in AutoCAD if the weights of vertices are all 1.0 (a B-spline and not a NURBS).  The worksheet compares the accuracy of a degree 3  B-spline  (AutoCAD spline) for 180°with a true sine curve.   Macros must be enabled for the Excel file to use the custom Excel BSPLINE function.
lee.minardi
Kent1Cooper
Perhaps >this topic< may be of interest to you.
Kent Cooper, AIA
TheCADnoob
fantastic points
CADnoob
