Frozen Model Space in Viewport
cliffordjohnturner
Message 1 of 13
cliffordjohnturner
Just this morning, I find that when I switch to Model Space in a viewport, everything is frozen.
But if I Tilemode to "1" and am in Model Space, everything is free.
If I go back to Paper Space, everything is still frozen in that viewport.
I checked to see if some layer is locked, but, no that's not it.
The viewport is itself is not locked.
I restarted AutoCAD, but that didn't help.
Any ideas out there ?
Replies (12)
Message 2 of 13
pendean
Community Legend
Community Legend
A Layout viewport has the option to OVERRIDE layer settings from modelspace: is that perhaps what you are facing?
Or is the viewport looking at the wrong spot in modelspace?
Share your DWG file here if you are unsure about either.
Message 3 of 13
cliffordjohnturner
I never know about the overide, but when I pause over the viewport border, some info is displayed.
At the bottom of that list is "Layer property override No"
What does that mean ?
Message 4 of 13
Patchy
Copy and paste these lines into your command line, then type in VPT
All your layers in the viewport will THAW
(defun c:vpt nil
(setvar 'cmdecho 0)
(command "_.VPLAYER" "_Thaw" "*" "_All" "")
(setvar 'cmdecho 1)
(princ)
Message 5 of 13
paullimapa
share your dwg with this problem
Paul Li
IT Specialist
@The Office
Message 6 of 13
cliffordjohnturner
Here it is.
Message 7 of 13
atGK8NU
Everything is not frozen when I enter model space in your viewport.
Can you send a screenshot of what you see when you enter model space inside the viewport?
Message 8 of 13
cliffordjohnturner
Message 9 of 13
paullimapa
Recommend using Windows Snipping Tool to just select the area of the screen instead of capturing the entire window
https://support.microsoft.com/en-us/windows/use-snipping-tool-to-capture-screenshots-00246869-1843-6...
Paul Li
IT Specialist
@The Office
Message 10 of 13
atGK8NU
Thanks for the screenshot.
It looks like you are in paper space in that screenshot. You said that your linework is frozen whenever you enter model space in your viewport. As you can see from my screenshot from model space, I don't encounter that issue. So if you could double-click inside your viewport and send a screenshot of what you see (and don't see) in model space, that would be helpful.
Message 11 of 13
paullimapa
I think I know what you mean
I assume you are selecting the Vport and double clicking on it which activates the VPMax command
Then the Vport fills the screen and nothing shows up like this:
Now if you use the ZOOM EXTENTS
Now you'll see the objects in Model Space:
Use the ZOOM Window command to view the area desired.
Use the VPMin command to go back to the original Layout view
Now the reason why this happens because you actually have 2 Vports with 1 on top of the other.
The one on top is the one that actually is looking at an empty area of Model space.
See I just moved the blank Vport onto the right side:
So now when you double click the Vport on the left you'll see objects
But when you double click the Vport on the right you won't see any thing.
Paul Li
IT Specialist
@The Office
Message 12 of 13
johntk22
verify that the layers within viewports are set to visible. Sometime the individual layer in viewports are set to off frozen,  which cause the object on these layer appears frozen.
Message 13 of 13
pendean
Community Legend
Community Legend
TWO?
