Format tab not showing?
Message 1 of 10
I am using the Autocad 2016 tutorial (attached).
It says to select Format on the menu bar:
My Autocad does not show this.  Instead it shows:
How can I get the Format tab?
Thank you for your help.
Replies (9)
Message 2 of 10
hmsilva
Hello Bruce,
It's not 'Format tab' it's 'menu Format', you'll have to put the menus visible...
Hope this helps,
Henrique
Message 3 of 10
That worked.
Thank you very much.
Message 4 of 10
hmsilva
@Anonymous wrote:
That worked.
You're welcome, Bruce!
Glad I could help
Henrique
Message 5 of 10
Thanks Henrique,
It's useful to me as well.
Hello Bruce,
Hope this helps,
Henrique
Message 6 of 10
Thank you so much. 🙂
Message 7 of 10
jvenegas1973
Community Visitor
Community Visitor
Thank You! I hate how Autocad now assumes that you know where everything is. Hiding **** doesn't help! Their instructions need to be more explicit. Thanks for the help! Very useful!
Message 8 of 10
jvenegas1973
Community Visitor
Community Visitor
Where in the hell is your "drawing setup" according to your instructions to go into the "Format Menu"? I finally found the format menu with the help of this forum but there is no "Drawing Setup" in there! WTF!😠😡
Message 9 of 10
cadffm
In AutoCAD it means the Units Dialog,
Menu Formats/Units
or Command Units
There you can set Lunits (like Decimal) and Insunits (Meter, for example).
In Toolset ARCHITECTURE - what is another software,
Command UNITS
open another Dialog dialog
My questions is WHY? Why are you trying to find a dialog you don't know what the content is!?
Sebastian
Message 10 of 10
pendean
Community Legend
Community Legend
Greetings @jvenegas1973 We are all end users over here just like you around here. Whom are you speaking with exactly?
1) your tutorial is from an older program, no longer relevant.
2) "drawing Setup" is not a plain AutoCAD feature (your program screenshot with the black background), you are using the incorrect variant for that ability. You also seem to be referencing incorrect tutorials for plain AutoCAD.
What variant were you hoping to be using instead?
For example, it is found in this variant over here from the red A in the top left corner of the program window, which also does not have pulldown menus at all anymore
