Automatic Enter
Automatic Enter
Message 1 of 8
Automatic Enter
I have experienced one big problem while working in Autocad 2016.
It seems like suddenly while working something happens and Autocad stops working correctly.
While entering a commad like polyline or move or rectangle etc. it seems like autocad automatically press enter.
For example if I press command Move with keyboard ''M-Space'' it automatically ends command without letting me select objects. (Screen shot 2) If I go on icon ''move'' it automatically select distance so I can't select base point (Screen shot 3). Seems like when i start command it automatically press eneter for one time and skipp one line of command.
Does anybody had similar issues and maybe know the answer ?
Tx
Replies (7)
Message 2 of 8
Alfred.NESWADBA
welcome @Anonymous.autodesk.com!
Make your command-line docked, this handles keyboard entries better.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 3 of 8
Kent1Cooper
Could you have a faulty keyboard, in which the space bar is registering twice when you press it?
Kent Cooper, AIA
Message 4 of 8
Hi @Kent1Cooper
faulty keyboard can't be the problem, because this problem occurs suddenly while using Autocad normally, also if I press on command icon, without using keyboard it also skip one command step (like he press enter for one time all by himself).
It happened to me on 2 different computers with different keyboards. Sometimes it works normal, and then in 1 of 20-30 times this problem occurs.
Message 5 of 8
tenk you @Alfred.NESWADBA. My command line was docked while this happend.
Message 6 of 8
Alfred.NESWADBA
Your screenshot shows that the commandline is not docked ...
- alfred -
Alfred NESWADBA
Message 7 of 8
Hi @Alfred.NESWADBA
When this problem occured commandline was docked. After that I tried to do all kind of stuff to find the solution. I was also moving the commandline, so when I took the screen shot commandline wasn't  docked. Sorry for not saying that in first reply.
Message 8 of 8
Alfred.NESWADBA
ok, second suggestion: turn off dynamic input (at least for a test period)
- alfred -
Alfred NESWADBA
