font style shows different in layouts
martin.mardikas
martin.mardikas
Hi!
In layouts same font style shows differently when I want to plot.
I have looked, plot options are all the same.
Any quess how to change that so these look same?
paullimapa
I’d double check to make sure they are really the same. Perhaps you can share a sample dwg that contains the differences so we can all take a look?
Paul Li
IT Specialist
@The Office
r.capper
The different font style may have been applied to the contents of the text object, not the whole text object. Click into and select the text in the object that looks different. You may find a different font applied to that text. If you select the text object it reports the default style, not any overrides applied to text inside it
Below Bodoni has been applied as override to text within an Arial Text object
Robin Capper
Design Systems Manager
LDE Ltd
TomBeauford
Depending on the type of font the difference in the apparent size and lineweight could be the cause if it's not a TrueType font.
64bit AutoCAD Map & Civil 3D 2023
Architecture Engineering & Construction Collection
2023
Windows 10 Dell i7-12850HX 2.1 Ghz 12GB NVIDIA RTX A3000 12GB Graphics Adapter
cadffm
huge Text,
isn't the same Font
ISP102/ISP112
Different size
Share this sample DWG and someone can show you the mistake.
Style and Font are different things.
Sebastian
