Foly line
Foly line
jostroopers
Foly line
jostroopers
Is it possible to make the line as in the attachment with Multi line tool?
Or is there a other way?
Mvg Jos
Youre drawings are as good as the symbols that compleet them.....
jggerth
if using C3D, and this is supposed to be a pipe, then C3D styles can handle that fairly well.
if just using as vanilla acad to get a line, then I would lay in a centerline using PLINE where needed, offset both sides, and then  Pedit the width if the original ot twice the offset distance. you end up with three objects,  instead of a single line.
jostroopers
Is there a lisp routine that can do this?
Mvg Jos
RobDraw
"Youre drawings are as good as the symbols that compleet them....."
Actually, symbols do not make a good drawing. They can help but they are far from THE determining factor. I've always said that symbols don't matter. Just have a look at the variety of ways the same design can be presented.
Grammar and spelling are much more important.
Rob
Kent1Cooper
In simplest terms, try this.  It assumes you start with a Polyline that has the desired non-continuous linetype and linetype scale.
(defun C:PPWE ; = Polyline Path Width with Edges
  (/ path pathobj wid)
  (setq
    path (car (entsel "\nPolyline path object to give width and edges: "))
    pathobj (vlax-ename->vla-object path)
    wid (getdist "\nWidth: ")
  ); setq
  (vla-put-constantwidth pathobj 0.0)
  (vla-offset pathobj (/ wid 2))
  (vla-put-linetype (vlax-ename->vla-object (entlast)) "Continuous")
  (vla-offset pathobj (- (/ wid 2)))
  (vla-put-constantwidth pathobj wid)
  (princ)
); defun
This is what it does with something of HIDDEN linetype:
For your original drawing's configuration, you will need a linetype with dashes and gaps of equal length.  There's one called EVENDASH that I'm not sure comes with plain AutoCAD but I think may have come with Architectural Desktop years ago -- if you don't have that, it's easy to make one.
It can be given all the usual enhancements -- verify that you selected a Polyline, and that it's not currently of Continuous linetype, remember your Width value to offer as default, *error* handling, Undo begin/end wrapping, etc.
Kent Cooper, AIA
