Flexible Duct
Flexible Duct
kimberleylou
Message 1 of 10
Flexible Duct
kimberleylou
Can anyone tell me a step by step way to draw flexible duct in Autocad Lt 2015. Ideally from converting a polyline.
I have tried copying commands on forums but have had no luck.
If anyone could help it would be greatly appreciated because I have ran out of ideas.
Replies (9)
Message 2 of 10
Patchy
You have tried copying commands on forums but have had no luck because that command probably is a command that run an autolisp and LT can't do that.
Message 3 of 10
h_s_walker
Welcome to the Forums
These are the forums for full Autocad you need http://forums.autodesk.com/t5/autocad-lt-general-discussion/bd-p/43
But as to your question how flexible is it. Is it going to be straight with right angle bends?
If so you can do it with a polyline. Start your polyline and when you get to where it bends press A for ARC and draw your arc then press L for line to go back to straight lines
You can also OFFSET your polyine so you only have to draw it once.
Can you post a drawing so we can have a look?
Howard Walker
Left Handed and Proud
Message 4 of 10
kimberleylou
I have attached an example of the sort of the thing im trying to achieve. However not always at right angles, on site it can be striaght, slightly bent or curved.
Message 5 of 10
h_s_walker
Can you please repost the image as a jpeg.
If you draw your duct as lines and arcs (which I'm assuming you do) you can then make them into a polyline by using PEDIT.
PEDIT
M
Select all your objects
CONVERT LINES AND ARCS TO POLYINE. Y (for YES)
J for JOIN.
Then your lines and arcs become one polyline
Howard Walker
Message 6 of 10
kimberleylou
I have uploaded it as a Jpeg file
Message 7 of 10
Patchy
Yup, It's autolisp and  LT can't do it.
Message 8 of 10
pendean
Community Legend
Community Legend
It would take you forever to draw that in LT. You need to upgrade your software to $4000 AutoCAD or $6000 MEP AutoCAD to get the correct tools or add-ins you found on the Internet or wherever.
Are you creating contract documents for a builder or contractor? The MEP engineering pros simply provide a curved Pline or Spline single line representation of a flex duct and put a note next to it calling it a flex duct. Nobody draws it like your image except maybe in high school or freshman year in college.
Message 9 of 10
dbroad
Kimberly,
There is no need on an HVAC plan to be that detailed when drawing flex duct.  Try this.  Draw the centerline of your flex duct in whatever curvy shape you want using polylines.  Change the global width of the polyline to the flex duct size.  Then change the linetype to dot or dot2.   Voila.
Architect, Registered NC, VA, SC, & GA.
Message 10 of 10
Kent1Cooper
That does seem over-literal compared to what is usually done in construction drawings.  I use something that's like a more-tightly-zigzagged ZIGZAG linetype, available [with an image of what it draws] here.
Kent Cooper, AIA
