FLATSHOT Failed
FLATSHOT Failed
Karol-Or
Message 1 of 9
FLATSHOT Failed
Karol-Or
I get the prompt:
FLATSHOT operation did not generate any geometry
Replies (8)
Message 2 of 9
Alfred.NESWADBA
for me (AutoCAD 2017 Update 1.1) it's working, with exact the state you have used while saving the file.
So something seems to be different ... let's start with AutoCAD version and service pack you are using.
Maybe a screenshot can help after you started command _FLATSHOT so we can see your settings.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Message 3 of 9
imadHabash
I try Flatshot and every this is going fine (see attached image)
I notice that there is an xref files attached,maybe xref files are the reason for failed operation.
Imad Habash
Message 4 of 9
Alfred.NESWADBA
That are TIFF files, not drawings, so these are not involved in the _FLATSHOT command 😉
- alfred -
Alfred NESWADBA
Message 5 of 9
john.vellek
Hi @Karol-Or,
I too had no problem with FLATSHOT in AutoCAD 2017
I also tested in 2014-2016 without error.
Are you receiving any error messages?Are you exporting to a file? If so, is the file location accessible and do you have permissions to write data there?
John Vellek
Message 6 of 9
Karol-Or
Ver 2013, i don't find the service pack version, where?
I tried FLATSHOT with Insert as Block option instead of writing to a file with no help, same message
Message 7 of 9
imadHabash
HI,
>> Ver 2013, i don't find the service pack version, where? <<
you can start from Here
Good Luck...
Imad Habash
Message 8 of 9
Karol-Or
So 2013 SP 2
Message 9 of 9
john.vellek
Hi @Karol-Or,
I am not sure why your Flatshot isn't behaving when the rest of us seem to get this to work without any problems.
Just for another option, I used Viewbase to generate views of your model and then did an EXPORTLAYOUT. Perhaps that will help.
John Vellek
