AutoCAD Forum
Fix distance between leader lines
4 REPLIES 4
seanNKRS3
373 Views, 4 Replies
Can anyone tell me if there is a way of fixing the space between leader lines in order to keep everything uniform?
4 REPLIES 4
rkmcswain
in reply to: seanNKRS3
Leaders or Mleaders? With Mleaders, the MLEADERALIGN or MLEADERCOLLECT commands may help.
GUID-DB501C4F-1BAB-4ADF-AC66-F090F408FED3
GUID-3A9A7049-1066-4D22-9191-8F7224CA3B66
seanNKRS3
in reply to: rkmcswain
Thanks for coming back to me - I'm trying to achieve what you see in this pic here. I have tried using the grid but I often find that the grid doesn't line up with the icon boxes meaning my arrows are off center.
Thanks again for any help.
pendean
LEADER and MLEADER cannot emulate your graphic without you knowing ahead of time how many clicks (bends) you need for each then draw each individually while you have SNAP turned on and set to a preset spacing for this bottom portion.
seanNKRS3
in reply to: pendean
OK, so the grid is the answer then.
I can see how to achieve this now, thanks.
Technology Administrators
AutoCAD Beta
