Fix blocks marked with error in the Count Tab
jtm2020hyo
jtm2020hyo
I have not idea what mean this error symbol, its this related to overlaping lines or hatch?
jrreid
Does any of your blocks have funky characters?
{} [] etc...... See example below. If so rename your blocks and re-run.
Even BCOUNT will not recognize these characters.
I did a search and found this and had similar issues:  block count error - Autodesk Community - AutoCAD
Hope this helps.
JRR.
jtm2020hyo
Finally I found the problem
I use AutoCAD Architecture and MEP and when Block sometimes are renamed like anonymous blocks, no idea why.
anyone know how can I rename all blocks? I tried ResetBlock Command but no luck.
