Find source object in model space of a viewbase object in paper space
bcsnyder2
bcsnyder2
My model has several parts and the drawing contains 25 tabs.  How can I select a 2D object in paperspace and locate the 3D source for that object in model space?  I am using AutoCAD 2024.
TheCADnoob
You can find the object by editing the viewbase selection. You can either double-click the viewbase or right-click and select edit. Once there, click model space selection. This will bring you to the location of the item in model space.
CADnoob
bcsnyder2
When I double click the viewbase object the following appears in the command
line:
VIEWEDIT Select option [sElect Hidden Lines Scale Visibility eXit] :
When I enter an "E' for select and then enter, I get the prompt "Select is
not supported by the model or view type."
When I right click on it the command.VIEWEDIT appears and the prompt "Select
view". When I select a view
It carries me right back to "VIEWEDIT Select option [sElect Hidden Lines
Scale Visibility eXit] :"
I haven't found a prompt that reads "model space selection" nor have I found
an option to edit.
TheCADnoob
any chance you can share the file?
CADnoob
bcsnyder2
It is a large structural steel configuration.  I can't share it as I've signed a NDA with the client.  So I created a simple drawing with four geometric shapes on it for trial.  I opened layout1 and used viewbase to insert 2D drawings of one of the objects.  Next I double clicked on that object in layout1, entered E for sElect and got the same message, Select is not supported by the model or view type.  Here is the drawing.
bcsnyder2
Flash - I just tried it in AutoCAD 2021 and it worked.  For some reason it isn't working in AutoCAD2024.  Is there a system variable that I need to change?
TheCADnoob
Hmmm... ill have to test it on a 2024 system and see if I get similar results.
In the meantime here is a list of the new commands and system variables for 2024
https://help.autodesk.com/view/ACD/2024/ENU/?guid=GUID-B93A458E-1A7F-4090-A8CF-87A31C24E404
CADnoob
