FIND AND BLOCK BUG
FIND AND BLOCK BUG
PPPLJHSDRTYDSKJ23940900HB
Observer Observer
FIND AND BLOCK BUG
Observer
Observer
WHEN I GIVE THE COMMAND "FIND" I GIVE "REPLACE ALL" AND ASK TO CHANGE WITHIN THE BLOCK AND OPEN THE BLOCK I LOSE EVERYTHING I DID WITH "FIND"
pendean
Community Legend
Community Legend
Is this a sudden new problem?
Or is this a new PC/setup or a new office?
Did your restart your PC to see if that clears the issue?
Is your Windows login of the restricted and limited type (you are not able to install software updates for example)?
RSomppi
Are these attributes? Maybe ATTSYNCH fixes the issue?
Observer
Observer
1. old computer
2. yes, I restarted, including the problem that even if you do find, save the file. close the file. and open again. if you open the block it resets find again.
3. I am the machine's admin.
 The problem is even if you do find, save the file. close the file. and open again. if you open the block it resets find again.
pendean
Community Legend
Community Legend
@PPPLJHSDRTYDSKJ23940900HB Either your block has a badly defined attribute.
OR
you are not saving your DWG file after FIND command completes its task.
OR
you are actually trying to change an XREF, but it reloads as is.
Share with us this problem block inside your problem DWG file, point to it, explain what all you placed in FIND so we can replicate it.
