The fillet command on my machine no longer seems to work. I have sent the .DWG to my colleague and it works fine for him.
I have carried out searches on the web and this forum but found no answers. below is the command history
FILLET
Current settings: Mode = NOTRIM, Radius = 0.00000000
Select first object or [Undo/Polyline/Radius/Trim/Multiple]:
Select second object or shift-select to apply corner or [Radius]:
Both lines are on Z=0, as far as I can tell.
I have a lot of badly drawn drawings (supplied by others) and the fillet command, where radii is set to 0 is a great time saver.
If I change the radii to give me a radius, it does a radius but leaves behind a bit of one of the lines, not trimming it out I think.
It did use to work ok.
Any advice please.
many thanks.
