Fillet not working
Fillet not working
cr74steve
Fillet not working
cr74steve
The fillet command on my machine no longer seems to work. I have sent the .DWG to my colleague and it works fine for him.
I have carried out searches on the web and this forum but found no answers. below is the command history
FILLET
Current settings: Mode = NOTRIM, Radius = 0.00000000
Select first object or [Undo/Polyline/Radius/Trim/Multiple]:
Select second object or shift-select to apply corner or [Radius]:
Both lines are on Z=0, as far as I can tell.
I have a lot of badly drawn drawings (supplied by others) and the fillet command, where radii is set to 0 is a great time saver.
If I change the radii to give me a radius, it does a radius but leaves behind a bit of one of the lines, not trimming it out I think.
It did use to work ok.
Any advice please.
many thanks.
tramber
You are in mode NOTRIM !
Choose the Trim option and change it 😉
by doing the next trimming.
Or change the variable TRIMMODE to 1
Valentin_CAD
@cr74steve,
Try setting your REGENMODE Variable to <1>
See similar issue >>here<<.
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
cr74steve
Thought that that might be the case but can not seem to find to reset trim mode. Can you give me a dummies guide please.
cr74steve
Found it, Thank you. Double dose of stupid pills this morning. No idea how the mode got changed, I do not play with settings.
Many Thanks
