Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
Files not opening/ saving as DWG
molliemae_grant-west
Community Visitor
Community Visitor
Due to my files not saving as a DWG I am not able to open my CAD files using the software.
I have uninstalled the programme and reinstalled twice, this problem is still reoccurring.
please help 🙂
windows cannot find 'c:\program Files\Autodesk\AutoCAD 2023\acad.exe'. Make sure you typed the name correctly, then try again.
jayhar
Did you Check FILEDIA <1>
Try it and replay
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly.
paullimapa
perhaps try downloading the latest version which is 2024
Paul Li
IT Specialist
@The Office
Valentin_CAD
@molliemae_grant-west ,
Welcome to the AutoCAD forum.
Contact your IT Department to help you fix it with this article:
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
Community Visitor
Community Visitor
I have already done this. Any other suggestions?
Community Visitor
Community Visitor
This has not changed anything. Any other suggestions please?
pendean
Community Legend
Community Legend
@molliemae_grant-west wrote:
Due to my files not saving as a DWG ...
That is odd: is this perhaps just a problem of you not having file extensions on in Windows File Manager and you assume whatever wrong label got assigned to DWG files means they are somehow all gone?
You'll need to show us what you mean, what you see and where you see it, with lots of screenshots.
Or just do this https://fileinfo.com/help/windows_10_show_file_extensions
OR... open a support case with Autodesk if you are on subscription to seek out Autodesk Support's help:
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/How-to-find-my-sup...
EDU Support Access is here, look for the new automated pop-up with common questions
https://www.autodesk.com/education/support?startHelpBranch=AVA-edu-flow&mode=open&_ga=2.35539169.196...
and here https://forums.autodesk.com/t5/installation-licensing/education-license-renewal-lacks-renew-option-o...
