within your drawing you have details (extremely small) which I guess you even might not know that they exist?
Zoom to Window (in modelspace)
299733.5557,97819.7376 to 299734.4742,97820.3962
There you find 1 hatch on layer "Deckenschraffur" based on elements with multiple thousands of vertices, you can see which hatch it is as it shows some diagonal lines, so the hatch don't get it's borders together. Erase this hatch, save the drawing with a new name and close it and open the new drawing.
So the conclusion is that (besides of unnecessary geometry, I think) there is one hatch which tries to recalculate it's display and it needs too much processor power.
Complete drawing, red arrow points to the position where you find the detail
Zoomed to detail, pointer shows to diagonal lines from the defect hatch:
Unlock the layer "Deckenschraffur", select the hatch (needs a bit of time until it is selected) and erase it.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ...
blog.ish-solutions.at ...
LinkedIn ...
CDay 2025------------------------------------------------------------------------------------
(not an Autodesk consultant)
