file size gets bigger
This file gets bigger and bigger whatever I do.
I tried auditing, purging, pasting to a different file, saving to latest version.
I can't figure out if the file actually has to many lines or if there is something wrong with it.
can anyone help me?
WarrenGeissler
Start by changing your ISAVEPERCENT to 0 and saving a few times.
Warren Geissler
Drafting Manager Denver Water
_____________________________________________
Please ACCEPT AS SOLUTON if this works
(...and doesn't melt your computer or cause Armageddon)
imadHabash
all this happened because of the hatch  . you have a lot of hatch and with transparent . try to separate your file components and start to attache them as an xrefs . also clean your dwg to delete all registered elements bu Purge ( reg) command .
Regards.
Imad Habash
Hi
This file was sent to us from a landscape group. They used a lot of hatches, wipeouts and excessive drawings.
Saving to another file makes the biggest difference but I guess it needs to be cleaned out and it's not a systematic problem. I gave up 🙂 sent the file back and reported on how they need to do their next drawings.
This file was created and sent to us by another group, I didn't realize they used transparencies, thank you for pointing out.
jayhar
50% Size reduce, use command "WBLOCK" . please find the attachments
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly.
