File Path Display on Screen
Message 1 of 18
I sometimes have a white box on my screen, that is not part of the drawing (ie not t text box), that references a file that is not open at the moment.  It hovers over my layout and I have to pan in my drawing to see.  It doesn't seem to happen in all drawings but the file it is referencing isn't associated with the same project so should have no reference to it.
Any ideas?
Replies (17)
Message 2 of 18
imadHabash
Would you show us the case please?
Imad Habash
Message 3 of 18
tmccar
Is it pointing to an XREF that is not available?
Message 4 of 18
In the XREF MANAGER, are any drawings not found?
Message 5 of 18
I don't understand your question. Are you looking for a screen shot? It has gone away, as it sometimes does, but is sure to come back.
It is similar to the box that appears when you hover over the tabs of open drawings at the top. It shows that drawing's path and file name but that one disappears when you move your mouse away. For some reason, I sometimes get one in the middle of my screen that stays. When I begin to type a command, it goes, then comes back.
Message 6 of 18
The latest file does not have any xrefs and the only xrefs are usually my border logos.
Message 7 of 18
Sounds like a display issue.  Do you have the latest video driver?
You can check if your driver is the latest 'certified' driver with the below link:
http://usa.autodesk.com/adsk/servlet/syscert?id=18844534&siteID=123112
Message 8 of 18
I am having the same issue.
The persistent path even shows up in front of other application windows.
When I try to open xref manager, it says '** EXTERNAL REFENCES command not allowed during reference editing **
I am not in any refedit command. I was editing a block in-place shortly before this happened though.
This happens to my co-worker fairly often.
Ben
AutoCAD 2016 M.49.0.0
Windows 7 SP1 64 bit
Message 9 of 18
pendean
Community Legend
Community Legend
Close and restart AutoCAD, does your problem go away?
Message 10 of 18
Yes, it does. I'm wondering why it happens and what the difference would be between my workflow and my co-worker's. Or maybe it's a hardware difference, I don't know.
Message 11 of 18
Try toggling your hardware acceleration.
Message 12 of 18
Message 13 of 18
laura_studiobondy_com
Try turning off the Start screen.
STARTMODE 0
Message 14 of 18
THAT FIXED THE PROBLEM!
Message 15 of 18
This fixed the problem for me!
Message 16 of 18
The solutions is here:
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/File-n...
Startmode - 0
It solved this problem in my Autocad 2016.
Message 17 of 18
siddheshpatkar92
Community Visitor
Community Visitor
It work's for me, thank you.
Message 18 of 18
xanjay_chawla
Community Visitor
Community Visitor
It worked. Thanks
