File not showing in layout
ShifraSpiegel
ShifraSpiegel
Any idea why the drawings attached are not showing up in my layout?
imankassab2015
The file is quite full of drawings double click on the viewport in the layout tab if you have one on the layout tab if you don't have use MV abbreviation draw a rectangle to create viewport then double click inside if you have one or just create it
Then use z enter for zoom window to choose which drawing you wish to see because there are many plans and sections after you choose the right one click outside the viewport window to fix it
Accept my answer if it helps you
cadffm
they are showing up in your layout! (as one pixel)
But all objects you are zoom to on model are sooooo tiny or better, the other objeects (you see in layout) are sooooooo hugh!
Take a look to my edited .dwg <attached>!
Sebastian
ShifraSpiegel
Thank you!
