Two users are reporting that sometimes one can open a DWG file that is already open on the other user's pc, and save it, without any warning. This has led to loss of data in the past. The user that had the file open is using Autocad 2016, and the user that opened it in the meantime is using Autocad 2014. Both are opening the file through a Windows share on a Windows Server 2012 in the local network.
Any idea why this might be happening?
Solved by john.vellek. Go to Solution.
Hi @Anonymous,
I see that you are visiting as a new member. Welcome to the Autodesk Community!
I am sorry that your users have overwritten files and lost some work. Dean is correct that file locking is not controlled by AutoCAD. Here is an article that provides a bit more information.
I have seen this in the past when system clocks are not synchronized, when there is a DFS in place, and also when a user thinks they are opening a file from the same location but is actually opening a different file.
Are any of these a possibility? How are your clocks being set (NET TIME)?
Hi @Anonymous,
I am checking back to see if my post or Dean's helped you with your problem. Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
Thank you both for your suggestions.
We did find significant time differences between the server and the clients, and we fixed that. We're confident that may have been part of the problem but since it wasn't reproducible, we can't be sure, so we're going to wait and see if another issue pops up.
I'll make sure to accept the answer then. No such issue has popped up so far.
Hi @Anonymous,
I am glad that this might have been an easy fix. This should also help in working on your network with other applications as well.
I assume that you are now pushing the time to network clients from the server and that the server is configured to get its time from a known external source.
If not, and you need some help, let me know and I can point you to some additional resources.
