File became unusable beacuse of lag and calculation
davide_dp04
davide_dp04
Community Visitor
Community Visitor
Hi, I'm using Autocad for three weeks, I'm new to this program. While doing a section, I touch some button or settings in the layout 1 that I don't remember and don't know and from that moment the file became really laggy. When I have to add hatches and solid areas in an area between some line, it start making "calculation" and start to freeze, became unusable. Please help me out if you know how to solve this problem. Thanks!
Valentin_CAD
@davide_dp04 ,
Welcome to the AutoCAD forum!
@davide_dp04 wrote:
... When I have to add hatches and solid areas in an area between some line, it start making "calculation" and start to freeze, became unusable.
Try these suggestions:
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
paullimapa
Does this laggy problem occur only in this one dwg or on all dwgs?
Other than the Hatch command are there any other commands causing problems?
Do you have the latest AutoCAD updates installed?
Execute the About command, so a screen capture and share that here so others can see your current AutoCAD version
Paul Li
IT Specialist
@The Office
davide_dp04
Community Visitor
Community Visitor
In the other dwg is ok, in this dwg the problem was that I touched some settings that I didn't know and I make a mess. I ""resolved"" zooming while hatching but I don't know. Probably it's ok for now.
Other command have no problem, I have a nice pc and Autocad is fully fine, except in this particular dwg.
I'm a student so I have the Educational Plan, Autocad 2024 with the last update.
paullimapa
glad it's working ok for now...cheers!!!
Paul Li
IT Specialist
@The Office
