I am working in model space and have set up a table with fields that are linked to polylines of net area of rooms. However, the fields in the table will unlink for no apparent reason and will show #### instead. Is there a workaround so that I don't have to keep relinking the field object to the polyline over and over?
#### can also mean your table cells are not wide enough for the information trying to be displayed, did you check that?
Or are you somehow changing the Plines in any way?
Or copy/pasting into other drawings?
Or... ?
