Fields syntax modification
armanCUWLF
armanCUWLF
Hi all, Ill try to keep it short. I'm trying to edit some predesignated fields, such as paper size to display but in a different format, for example, papersize field currently displays the full plot name, size, followed by the full word "INCHES":
ANSI A (8.50 X 11.00 INCHES)
I would like to edit this to display (8.50 X 11) only, or maybe (8.50" X 11").
I want to know if there is a way to modify this format, or the format for any of the other pre-programmed fields. As I'm not seeing any user integrated means to achieve this. I want to know how I can edit the code in the AcFields.fdc file to achieve this, however, I'm not too familiar with the fields program syntax.
currently the file for firldId #67 reads:
</Field>
<Field fieldId="67" name="PaperSize" evalId="AcVar" fieldFormatType="String">
<DisplayName resource="217" src="AcFieldRes.dll"/>
<FieldCode>PaperSize</FieldCode>
<FieldCategories>Plot</FieldCategories>
<OptionDialog class="CVariableDialog"/>
Please let me know how I can modify this code.
Also please let me know if this is Lisp language or another back-end language different from lisp (I must work on my understanding of the LISP syntax).
thank you.
cadffm
that's not the job of fields and "ANSI A (8.50 X 11.00 INCHES)" it's just a paper definition NAME.
>"Please let me know how I can modify this code"
This hast nothing to do with your goal, AcVar is reading a sysvar - you can't create new function.
Let me ask you about your Layout&Plot technic.
Do you plot layouts always 1:1 ?
If so, I would go complete different way: A field inside your drawing frame/title.
Sebastian
cadffm
>>"please let me know if this is Lisp language or another back-end language"
No, it's no language. It's a core XML structure and the content/values are undocumented,
but senseful and easy to understand.
Sebastian
armanCUWLF
Thanks, I am simply trying to add paper size to the title block, along with other information (this should be ideally incorporated into the block, or placed on the a layout if necessary).
The layouts are printed based on the pagesetup for each layout, eg. 11x17, 24x36...etc.
Currently the default field that identifies papersize incorrectly defaults to ANSI A (8.50 X 11.00 INCHES), although I don't currently have a 8.5x11 layout.
I would like it to default to each layout based on the page setup print properties for each layout.
I also would like ideally customize the format that information is displayed to reduce much of the unnecessary information.
thank you.
pendean
Community Legend
Community Legend
@armanCUWLF wrote:
... I am simply trying to add paper size to the title block...
Isn't your titleblock an actual block with a predefined paper size already?
You can just add a static text in it anywhere you want. Why does it ever need to be a field if I may ask?
Or are you actually using a bunch of lines and Plines that you stretch (or move then constantly FILLET) every time you need a titleblock? Or are you scaling it constantly to avoid spending an hour, one time, to create different sized titleblocks to use forever? I'm curious more than anything else.
armanCUWLF
Sorry looks like my response didn't go through. I do have the title block as a block with many blocks nested, some which are standard and shared between different layouts, I guess it can be static, but would have to be in the border block. I wanted to have a field as some users may attempt to plot for example an 11x17 layout on a 24x36 paper (I know). In those cases the block will incorrectly display the wrong paper size or would have to be adjusted as a custom field or attribute.
