bak file
bak file
apanbasu
Message 1 of 15
bak file
apanbasu
I just noticed I do not have back files. There are pdf files but Adobe acrobat is not recognizing those files.. I have this software on my new machine for little over two months.
My setting is to have saving of file every 10 minutes.
Any suggestion?
Replies (14)
Message 2 of 15
RSomppi
It sounds like you've associated the .bak files to Adobe. Can you see the file extension?
Message 3 of 15
paullimapa
First, double check to make sure you have file extensions set to visible in your Windows Explorer just to confirm that there are .bak files created each time you do a save in AutoCAD
https://www.gottheknack.com/a-how-to/file-systems/file-ext-and-details-view/file-ext-and-details-vie...
Paul Li
IT Specialist
@The Office
Message 4 of 15
apanbasu
I have windows 11. It did not gave me the same screen as 10. View has different action.
Message 5 of 15
apanbasu
I am not how that happen. Where should I look for it.?
Message 6 of 15
paullimapa
searching on-line here's the instructions to show the file extensions on Win 11:
https://lazyadmin.nl/win-11/show-file-extension-windows-11/
Paul Li
IT Specialist
@The Office
Message 7 of 15
apanbasu
I have done what you have suggested and end up as shown in the attached Screen shot. It does not give any option to change extension. I see a file with extension .dwfx. Is this the auto save file?
Message 8 of 15
paullimapa
Your screenshot shows folders directly under your C: drive. But you need to open the folder location where your dwg file is stored and then look for a matching filename that has a .bak extension to rename as .dwg.
Paul Li
IT Specialist
@The Office
Message 9 of 15
apanbasu
That is not what I am trying to do. I want auto-save to be .bak file. In my old 32 bit machine I had 2028 version and the Auto-save files were saved automatically in .bak file. Now that is not happening. I have in option set up auto-save every 15 minutes and in .bak file. But that is not happening.
Message 10 of 15
paullimapa
Again run Windows File Manager and open the folder location where you have your typical dwg files stored.
For example your dwg files may be stored under My Documents.
Everytime you enter a command like QSAVE, a matching file name but with a .bak file extension will show up in the same folder location.
Auto-Save files are different and do not use bak extensions. Read up more on the differences discussed on this post:
https://forums.autodesk.com/t5/autocad-forum/autosave-bak-files-in-autosave-location/td-p/8320914
Paul Li
IT Specialist
@The Office
Message 11 of 15
RSomppi
Automatic saves and backup files have completely different purposes. I don’t think this is advisable.
Message 12 of 15
pendean
Community Legend
Community Legend
@apanbasu wrote:
...In my old 32 bit machine I had 2028 version and the Auto-save files were saved automatically in .bak file. Now that is not happening. ...
None of those statements are true in any previous or modern AutoCAD year version, Sorry. You are "mis-remembering".
You can just avoid ever using manual saves long enough that BAK files are eventually created, but for most of us that's a risky proposition.
Have you turned on file extensions in your new Windows File Manager yet? That will 100% cure your reliance on the unreliable WindowsOS labeling of file types and actually show you BAK pdf files for example.
Message 13 of 15
BudW
Message 14 of 15
apanbasu
Thank you.
Message 15 of 15
paullimapa
you are welcome...cheers!!!
Paul Li
IT Specialist
@The Office
