Fields and Multiline Attributes - EATTEDIT vs DDATTE
Is it my imagination or is there a bug when inserting/editing fields in a multiline attribute? I just updated my dynamic block section cuts to use multiline attributes, so I can make use of background masking, and I'm noticing some odd behavior. If I double click on the block the EATTEDIT commands is invoked. I can insert a field and exit the editor without issue. However, if I use the old DDATTE command, upon exiting the editor the changes are removed. It doesn't matter if I insert a field expression from the clipboard or insert a new field, the changes are discarded. I can add non-field data and the changes stay, so this appears to be a field only issue. Can anyone else confirm?
Thanks in advance. (Vanilla 2021)
