Field List Separator
bbrems3K829
bbrems3K829
Is there a way to remove the list separator in a field?
I created the field in an MText.
I want the XY coordinate with X on top and Y on bottom with no comma, semicolon, or slash between.
I have tried deleting it leaving that space blank but it defaults back to a comma.
I know I can do separate fields in the same MText but don't what to have to select the same object twice.
I have a ton of points and do not want to double my work.
Beth
pendean
Community Legend
Community Legend
You will need to use only the X then only the Y, side by side, but not both at the same time like you have checked in those boxes now.
