Field insertion problem to a custom sheet set
t.bamuqabel
t.bamuqabel
hi,
I've created a new custom sheet title (total sheets no.) to link it to my title block using "field", however when I tried to insert a field into my attribute block in the title block, I couldn't locate the custom sheet title that I've created, not under the "current sheet custom" nor "current sheet set custom".
Can you please assist me with that?
jayhar
You want to create a custom titleblock that can be used as a default template for your Project Navigator Sheets. click here
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly. If your issue persists,
Please give me a bit more detail on this issue so we can continue to work towards getting this solved.
Thanks You
Jayhar.M.J
Helpful Links: Prepare your computer for download |  Autodesk Virtual Agent | Clean Uninstall | Steps for Setting-Up Student Software
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
john.vellek
Hi @t.bamuqabel,
Is it possible to share your SheetSet and your titleblock where you are trying capture this custom field?  Which version of AutoCAD are you using?
If your data needs to be private or confidential, please email it directly to me at john.vellek@autodesk.com and please include a link to this thread in your email.
John Vellek
t.bamuqabel
Hi Mr. Vellek,
First off thanks for your help, I've attached a screenshot which explains the issue, "SS1" is where I created the custom property in the sheet set (total sheets no.), and "SS2" is where I couldn't locate the created custom property in the field window. What I need to do is to change the value of the (total sheets no.) in my title block from the sheet set manager.
My autoCAD version is 2018.
Sincerely,
t.bamuqabel
Hi Jayhar,
Thx for replying, however I was able to create a custom property, what I couldn't do is find it in the field window which enables me to insert the value of it from the sheet set manager.
john.vellek
Hi @t.bamuqabel,
I created a custom property in my sheetset such as you did and had no problems linking a field to it.  As a temporary workaround, you could put this text value into your titleblock if it is Xref-ed so it will show up properly.
To troubleshoot this further I would need to see your files.
John Vellek
