AutoCAD Forum
Field - Custom Scale Problem
6 REPLIES 6
stephanie_brandt
412 Views, 6 Replies
Hi there,
I have various scales set up in my layout from 1:10 to 1:1000. I have also one field text that is referenced to my viewport and it shows the name of my custom scale (Object->Custom scale->Use scale name).
When I update my field text it shows the corresponding name of my scale for every scale except for 1:1000. There it always updates to 1:1. Its odd because it works for all other scales but only this one doesnt show my scale name. My units are set to meter and scale 1:1000 is set as 1 paper unit = 1 drawing unit.
Labels (2)
6 REPLIES 6
cadffm
in reply to: stephanie_brandt
Acad search for custom scale name by ratio (1unit : 1unit)
and 1:1 have the same one, but is the first in order.
Change the Scales order (I think you don't have a viewport with annotation scale 1:1, so it isn't a problem)
ScaleListEdit, move 1:1 to the end (or just below 1:1000)
Sebastian
Could you share a dwg where you have these scales setup in your drawing especially the one that shows 1:1000 using SCALELISTEDIT command?
Paul Li
IT Specialist
@The Office
stephanie_brandt
in reply to: cadffm
Hmm sounds like a reasonable solution but it didnt help 😕
Here is the dwg
@stephanie_brandt ,
Use the Standard Scale instead of the Custom scale:
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
Emilio Valentin
Thanks, that and moving scale 1:1 to bottom of scale list solved the problem.
AutoCAD Inside the Factory
