FIELD CATEGORY
FIELD CATEGORY
rhao
FIELD CATEGORY
rhao
Is it possible to edit/add the Field Category and Field Names? i added a property set and was wondering if i can add
them to the Field Category and Field Names.
thank you.
pendean
Community Legend
Community Legend
That pop-up list is static, not user editable.
Perhaps there are other ways for you to reuse your custom field though: tell us what is it, what is it for, and more, lets see what else you can try.
vinodkl
It's not possible to create a new or edit the field category, but you can add a new field name into the "Document" field category by using "DWGPROPS" command. To do that open the DWGPROPS and then select the "Custom" tab, now click on "ADD" to add a custom property.
Now you will be able to set this as a field.
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
rhao
hi, thanks for you input. I did added a custom property but the property set I added is part of
the extended data which I manually type in the information for that certain object or block.
I was trying to create an attribute block with field data so I can extract the information from the extended
data I created.
rhao
hi, thank you for your input. I will try to come up with a better question or scenario. thank you again.
