Block attribute with Fields that will extract data from the object extended data
hi, i do not know if this is possible but here it is. i added an object property set definitions call EquipmentData and
under this i added 3 Manual Property Definition called AssetID, Category & TypeCode. so every equipment object or
block i have on my drawing, i will manually input those 3 property definitions. what i wanted to do is make a block attribute that will have those 3 property definition so that when i insert the block and hit the object, it will give me
the values i manually inputed for that object. i hope someone can help me on this if it is indeed possible. thank you in advance.
