FIELD AND TEXT INSIDE DIMENSION
vinodkl
The only way I could get this thing to work is by entering the values from the properties palette. Note that the text will again be turned into a field if you try to edit it by double-clicking the dimension.
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
Alfred.NESWADBA
what happens when you change the array (make it longer/more items/so that 15 is not a valid number any more) ... then exchange field to "15" ... then reduce the array back to it's original size?
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
R_Tweed
The quick fix for me was to insert a field as a formula and write it as =15*1.  That fixed the linking issue.  You might want to do something different moving forward if you are looking for that formula to yield an answer. Perhaps you you might want to have a text or attribute reference as that constant.
Hello
Thanks for the answers
I found a way by adding suffix or prefix in Additional Format -> Additional text
For example pcs, cm, etc.
So field value is (formula) + suffix / prefix
