February Expert Elite Highlight : Luciana Klein's guide to AutoCAD
Azmeera.M
Alumni Alumni
Message 1 of 16
Azmeera.M
We're proud to introduce Luciana Klein as our first guest author of the 2016 Expert Elite Highlight series. This Brazilian powerhouse shares step-by-step instructions on how to set up the Classic Workspace in AutoCAD 2016. Also check out Luciana’s story on how she stumbled upon becoming an expert of AutoCAD.
WHERE IS THE CLASSIC WORKSPACE IN AUTOCAD 2016?
This is one of the most frequently asked questions in the forums and groups.
Since AutoCAD 2015, the Classic Workspace is no longer available as part of the product, but let me share this info with you: you can easily create your own Classic Workspace, as the toolbars are still there.
The discontinuation of Classic Workspace is part of the product’s normal progression, but there are many professionals who prefer working in the classic environment over the ribbons. I love the ribbons and I suggest that you do not give up, as your work will certainly be much more productive.
However, my job is to provide solutions (as best as possible), so I’m happy to share with you how to create your own Classic Workspace!
There are two ways to restore Classic Workspace in AutoCAD 2015 or 2016. I will demonstrate one of them in this article.
Here we go!
Open AutoCAD, type CUI and press <Enter>.
The Customize User Interface dialog box will open. Select the Workspaces category, right-click on it and choose the New Workspace option:
Type the name for your new workspace (here I entered 'My Classic'):
Now we are going to define what this workspace contains.
Click on the Customize Workspace button:
Now is when the magic happens!
You need to click on the Toolbars that you want to activate in Workspace Classic, so click on the + sign beside the Toolbars category and select the ones you want to activate:
Please note that the toolbars that you select in the left panel will show up in the right panel; for example, the Draw Toolbar shown in the image above.
Make sure to select the Quick Access Toolbar, the Menus and the Express Menu so that you can have the full Classic Workspace:
To finish, just click the Done button, then the Apply button and finally, click on OK:
You will see that the newly created workspace is now featured in the list of workspaces:
Select your new Classic Workspace, and your AutoCAD 2016 screen will look like this:
A little messy, isn't it? And where are the Menus? What is this empty Ribbon doing in my screen?
Easy! Let's fix this!
First of all, we must set up AutoCAD to save the changes made in Workspace. Otherwise, whenever you open AutoCAD again or choose another workspace, you will have to reorganize everything! You don't need this: time is precious!
So, access the Workspace Settings:
Select the Automatically save workspace changes option and click OK:
If you don't want the Ribbons (remember we didn't select any tab or panel in the Ribbons category when we were creating the new Workspace),
you just have to pull up the RIBBONCLOSE command and that's it! They are not shown in the screen anymore:
What about the Menus?
Click on the arrow at the end of the strong>Quick Access Toolbar and choose the Show Menu Bar option:
Drag the toolbars around to organize their location in your screen:
But we're not finished yet!
Anyone who uses toolbars knows that sometimes, when we click on an icon, we unintentionally move it. We can lock the interface element locations so that this doesn't happen anymore.
Find the Lock User Interface icon at the end of the Status Bar:
Select the Docked Toolbars/Panels option:
And we're done! Now the toolbars are locked in the position you have defined!
How do you know if the toolbars are locked?
Check if there is a gray bar at the start of each toolbar.
In the image below, the gray bar is shown. This means that you can move the toolbars around your screen:
In the image below, the gray bar is not visible. This means that you cannot move the toolbars around your screen:
That’s it! This is the way I recommend setting up Classic Workspace in AutoCAD 2016.
For the other way to restore Classic Workspace in the 2015 and/or 2016 versions, watch THIS video (in Portuguese):
If you would like to watch a tutorial in English, please leave a comment in this article and I will provide a new tutorial!
About Luciana
LUEXPERTELITE.jpgMy story with AutoCAD started in 1997. I decided to learn about AutoCAD because of my son.
Let me explain, my father passed away the year after my son was born. I was a single mother and was responsible for my household. At that time I was working in an accounting office and needed to earn more. I heard about a competitive examination for a job at the City Hall in my town, but AutoCAD was required. I needed to pass that examination!
With some help from my friends, including assistance in paying for the AutoCAD R13 course, I studied hard. I had no computer, so I used to imagine the software screen and the command sequence. One of my friends gave me a book, which was my night reading for months: George Omura's AutoCAD R13. Two months after starting the AutoCAD course, I took the competitive examination and came first in all tests, including AutoCAD. I started working in the Urbanization and Enrollment department and had a lot of support from colleagues and leaders. In 1998, at the suggestion of my boss, I started to teach private and in-company classes. Shortly after that I was working in two other computer science schools ministering AutoCAD courses, had private students and still held my formal position in the City Hall.
At that time, it was unusual to hear about CAD managers or CAD support, but that was essentially what I used to do in addition to my job as a construction register designer: I solved my colleagues' problems regarding the software, and developed small LISP routines to make the team's work easier.
In 1999, Autodesk promoted Planet Autodesk in São Paulo. There I attended a lecture by Lynn Allen for the first time and – dare I say it – I am her #1 fan in Brazil. I have attended all Autodesk events in Brazil since then.
In 2001 I created my site, CADKlein, which is now one of the most accessed CAD Portals in Brazil. My goal is to share tutorials and help members solve their issues using the forum. The CADKlein site has over 29 thousand members. In 2003 I joined Autodesk's Beta Testing Team.
In April 2006 I created the CADKlein blog on BlogSpot, but in 2012 we created the official CADKlein blog, and since then I have used it to post tutorials, videos, and news related to our industry.
In 2006 I published my first book, and have published 8 AutoCAD books in Portuguese since then. I am working on more books now.
In 2007 I started posting videos on my YouTube channel. In 2008 the Comunidade de Usuários da Autodesk Brasil (Autodesk Brazil User Community) was launched. I was one of their first collaborators and am still part of this Community.
I attended many Autodesk University events in Las Vegas and in Brazil, and have been a Portuguese speaker in many AU Virtual classes. I was awarded the Best AU Virtual 2011 Speaker Award with my lecture on parameterization in AutoCAD 2012.
In 2013 I was invited to be part of Autodesk Expert Elite, I was a speaker at AU Brazil events from 2011 to 2014.
In 2015 I gave my lecture in English at AU Las Vegas.
I graduated in Industrial Design in 1992. I was an AutoCAD and Technical Design instructor in SENAI technical courses in Guarapuava (Paraná state) and Caçador (Santa Catarina state) for many years. I currently live in Brasília (Distrito Federal) and work from home. What do I do? I write books and e-books, shoot videos, post in my blog, answer questions in groups and forums, teach my Online Course students and, of course, sell my books and other products in my Online Store. Sometimes, I also travel to provide custom training in companies and give lectures at events around Brazil.
Thanks to Luciana for this wonderful step-by-step instructions to set up the Classic Workspace in AutoCAD 2016, and also for the amazing story on how Luciana arrived at where she is today. It is an inspiring story, and we know it will inspire even more people that it touches.
Please subscribe to our AutodeskHelp blog to learn about helpful product tips and tricks like these.
Also check out AutoCAD blog for valuable tips like the classic AutoCAD commands.
Azmeera M.
Autodesk Employee
Replies (15)
Message 2 of 16
filipefrancisco
Parabéns Luciana Smiley Wink
Filipe Francisco
Comunidade Autodesk - Português - Colaborador
Autodesk Certified Instructor | AutoCAD Certified | Revit Architecture Certified | Autodesk Expert Elite
YOUTUBE | LINKEDIN
Se a resposta resolveu o seu problema, clique em Aceitar como Solução isso ajuda os outros usuários a encontrar rapidamente uma resposta e Curta se gostou.
If the answer solved your problem, click Accept as Solution. This helps other users to quickly find an answer. And hit Like if you do.
Autodesk Community
Message 3 of 16
cadklein
Muito obrigada Filipe!!!
Abração!
Marque Aceitar como Solução e clique em Curtir.
Select Accept as Solution and click on Like.
Luciana Klein
LinkedIn | Instagram | Facebook | Twitter  | YouTube
Instructor Certified Autodesk | Colaboradora da Comunidade de Usuários Autodesk Brasil
Meu Site CADKlein
Message 4 of 16
wittenb
great article Luciana!!! Smiley Happy
Message 5 of 16
cadklein
Thank you Wittenb!
Luciana Klein
Meu Site CADKlein
Message 6 of 16
Parabens Luciana, excelente seu artigo!
Message 7 of 16
cadklein
Muito obrigada ServantsOficial!
Abraços!
Luciana Klein
Meu Site CADKlein
Message 8 of 16
Hi all,
Nice workaround for the classicspace.
But i'm a ribbon user but i hate it when the menubar is turned off...
At the commandline type: menubar
Then type "1" to turn it on or "0" to turn it off.
Message 9 of 16
Thank you
Message 10 of 16
dzanta
Very nicely done!  Cool post...learned a lot!  Thanks.
Dzan Ta, AEE, ASM, ACI.
Autodesk Community | Twitter | YouTube | Facebook | LinkedIn |
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
Message 11 of 16
elshawadfy
Thank you very much.. That was very useful..
Message 12 of 16
meowruser
I know this is an old thread, but you may be able to help.  You state "I love the ribbons and I suggest that you do not give up, as your work will certainly be much more productive.".  I must be missing something, because I find the ribbon a massive productivity killer.  As an example, I need to draw a line between endpoints of two objects that are far apart and located in crowded areas, requiring a repeating series of Zoom Window, Zoom Window again, pick the endpoint of the first object, Zoom Previous, Zoom Previous again, Zoom Window, Zoom Window again, pick the second endpoint, finish the line, Zoom Previous, Zoom Previous again, to get back where I started.  With the Classic workspace, I can float the Zoom toolbar and do all that zooming with single clicks.  With the ribbon, I have to keep going back and forth between the Draw and View menus, requiring more mouse motion and more clicks.  I freely admit that I have not been to training in years.  Can you lead me to a source that will show me how to make the ribbon work for me instead of against me?  I realize that like it or not, the ribbon is inevitable.  Thanks for any help you can provide.
Message 13 of 16
pendean
Community Legend
Community Legend
You read the spirit of the posting a little out of context.
For your specific ZOOM functions, Ribbon or not, and if you do not have any physical limitations, all of your ZOOM functions should be abbreviated single or two-letter typed abbreviations using one hand while you other hand stays on the mouse in the drawing space to activate those actions.
Hunting and pecking at a toolbar is just as inefficient as doing the same on the Ribbon for these basic often used functions.
And anyone at anytime can float a toolbar with the Ribbon on or off. No "classic workspace" needed unless you still like to hunt and peck for command buttons instead of speeding up with two-handed drafting in AutoCAD (again, if you do not have a physical limitation with using two hands).
HTH
Message 14 of 16
RobDraw
A good workflow usually utilizes a number of ways to interface with the program. Ribbon, (cough) toolbars, pallets, right click contextual menus, keyboard shortcuts, mind reading, etc. Any one of them alone is inefficient. Knowing them all and having them set-up for your tasks is essential.
Rob
Message 15 of 16
meowruser
Dean:
Thanks for your reply.  I am using COVID-19 time to catch up on a lot of learning I have been putting off for years.  One of those is dealing with an embarrassing lack of current knowledge about AutoCAD, especially since I am the 'go to' guy for CAD.
As for missing the spirit of the original post, what I saw beneath the clever technique was the seductive call of continuing to resist the ribbon.  My associates and I have been clinging to Classic workspace for too long.
I work in a primary metals maintenance environment where most of us who use CAD do so for only a small proportion of our time, so we never get really fluent with it.  CAD is necessary but not highly valued, if you get my meaning.
I have tried the one hand on keyboard, one hand on mouse approach described.  For me, having spent years teaching myself to touch type (reasonable successfully) muscle memory resists using the left hand for right hand keys.  My personal assessment is that floating toolbars are just about as quick in our environment.  That said, maybe I will try again.
The big win for me was learning from your reply that floating toolbars were possible in the ribbon environment. Knowing that something can be done always makes it easier to find out how.  I have, and I found out a bunch of other useful things in the process.
You have improved our CAD practice, although perhaps not quite as you intended.
Message 16 of 16
meowruser
Rob:
...and here I thought I did all the things you suggest because I didn't know the correct way.  You just made my day.
