Fatal Error
Fatal Error
Message 1 of 11
Fatal Error
I am trying to copy a file from a drawing and each time I type "copy" the system crash and give me a fatal error: Unhandled Access Violation Reading 0xffffffff Exception at f94ec3bh
Replies (10)
Message 2 of 11
imadHabash
Hi and Welcome to AutoCAD Forum,
if this problem occurred in that file only , try to run the following commands :
  • PURGE > ALL (twice)
  • PURGE > Regapps
  •  AUDIT
if not fixed please try to test more than CAD file and see if any changes .
Imad Habash
Message 3 of 11
Hi! Thanks for the reply. Its not working. It gives me the same fatal error.
Message 4 of 11
imadHabash
would you try to install the latest service pack .
Imad Habash
Message 5 of 11
Yes, and nothing changes
Message 6 of 11
imadHabash
would you try solutions mentioned in this AKN article that may help . >> Click <<
Imad Habash
Message 7 of 11
Its still with the problem. We open the dwg in my friends computer and it gives the same fatal error when he tries to copy a drawing. We are trying to copy a table.
Message 8 of 11
imadHabash
is it possible to share here your CAD file ( as AutoCAD 2013 format type ) for testing please ?
Imad Habash
Message 9 of 11
I would love that but the table is confidential.
Message 10 of 11
cadffm
Table = Command table?
Open file with RECOVER didn't help?
The content should not be a part of that problem, clear the content or change values with nonsens or if the table is a dataextract table do it with the source content.
SaveAs new Name.
Try it again and
then upload the file.
Other objects and new tables works fine?
Command Copy or CopyClip?
I am sure someone can fix the problem, but without the file..
Sebastian
Message 11 of 11
Thanks! That Work!!!
