Fatal ERROR
Fatal ERROR
Fatal ERROR
Has anyone seen this error before and have a fix? In case the picture does not show I have typed it out below.
FATAL ERROR: Unhandled Access Violation Reading 0x86e0 Exception at d13a9545h. Capture.PNG
pendean
Community Legend
Community Legend
What were you int he middle of doing when it came up?
and can you repeat the problem on demand at any time?
The pop-up means nothing otherwise.
Sorry thought I had put that in my initial post. I was batch plotting to PDF, it has happened multiple times so far and every time when it gets to the third page in the set. I can take the same set of files and batch plot to PDF on a different computer and it works fine as I have already done so.
john.vellek
Hi @Anonymous,
If it happens on the third drawing can you attach that drawing and any xrefs?  Also, which version of AutoCAD (type ABOUT) and which PDF driver?
John Vellek
