Fatal Error
Fatal Error
Fatal Error
Hi....
I created a drawing with AutoCAD 2014 & revised it again with AutoCAD 2015
The final drawing was saved using AutoCAD 2015 c/w embedded photo
Then I tried to open my drawing with AutoCAD 2016 with no problem but when I click on the drawing for command, then the whole program crash with the following message as shown below:-
FATAL ERROR: Unhandled Access Violation Reading 0x0014 Exception at ce34e59dh
Can somebody help me, please ??
I'd tried opening it with AutoCAD 2015 & have no problem at all
Best Regards
Mak
kwoonheng.mak@aalborgportland.com.my
m_kingdon
Does CAD 2016 work fine on all other drawings?
You could try: save a copy of the drawing, open it in 2016 and use the AUDIT command.
Mike Kingdon
Civil 3D Zealot
Hi Kingdon
Thanks for your advises
I open the file & do an AUDIT but it still crash after that
I've no problem opening other files
Using AutoCAD 2015, I edit the same file & delete some embedded photos & save
Then I open the file with AutoCAD 2016 without any problem
So I'm suspecting the problem comes from my embedded photo which I'm going to try deleting one by one to find out the culprit
Best Regards,
Mak Kwoon Heng
Engineer
_____________________________________________________________________
Aalborg Portland Malaysia Sdn. Bhd. (275155-P)
(formerly known as Aalborg White Asia Sdn. Bhd.)
Lot 75244, Pinji Estate, P.O. Box 428, 30750 Ipoh, Perak
Phone +6 05 3218988 Fax +6 05 3222522
kwoonheng.mak@aalborgportland.com.my www.aalborgportland.com.my
CONFIDENTIALITY AND WARNING NOTICE. This e-mail is intended only for the person or
entity to which is addressed and may contain information that is privileged, confidential or
otherwise protected from disclosure. Copying, dissemination or use of this e-mail or the
information herein by anyone other than the intended recipient is prohibited. If you have
received this e-mail by mistake, please notify us immediately by telephone or fax.
Hi...
With reference to my problem of "FATAL ERROR: Unhandled Access Violation Reading 0x0014 Exception at ce34e59dh"
I've tried deleting 2 embedded photos in my drawings & finally, it's true that some of my embedded photo is the main culprit
After deleting the 2 embedded photos, I can opened my drawings without any more crash
Problem already rectify
Thanks alot guys for all the advises
