AutoCAD Forum
Fatal Error
6 REPLIES 6
539 Views, 6 Replies
Fatal Error
 jus had a fatal error on AutoCAD 15. It created recovery file, but not from current drawing. It was for another drawings that was opened as well, but called it current drawing name
6 REPLIES 6
pendean
OK
in reply to: pendean
Seen the error before?
pendean
Hart2015  .....Fatal Errors are unpredictable and i have seen this before  ... a few drawings open at the same time and recovery programme doesn't join the dots..  One solution if ever you get another FATAL eerror is to set the Autonmatic Save to say 2 mins into it's own directory for example c:\autodesk\AutoCAD temp files .. saves time and is a handy tool
That is for 2010 can I use for 2015?
It has been set at 2 minutes. It also created a recovery file, but not of the one I was working on and called it the file name I was working on (weird) @Anonymous
AutoCAD Inside the Factory
