Fatal Error when plotting
I have a file with 9 clipped dwf references, when I plot; a fatal error occurs. FATAL ERROR: Unhandled Violation Writting... Exception at bcfda607h.
I have audited and recovered the file and the one xref to remove any errors.
I have tried plotting in 2015-2016, In Civil 3d and autocad.
I have tried different prinnters and print to pdf.
When I delete the dwf's printing is fine (so, the dwf's are the problem)
What would cause attached dwf's in a file to crash the file when plotting?
John
Civil 3D 2016
pendean
Community Legend
Community Legend
What is your video card? PC specs?
Window 7 sp1, 64 bit
RAM: 6 GB
Processor: Intel 2.67GHz
Video Card: NVIDIA Quadro FX 1800
pendean
Community Legend
Community Legend
I should has also asked this as well, sorry:
What are you plotting to? Is the plotter predefined in the file? Does it crash as PLOT pop-up comes up or after you click OK to proceed with your plot?
I clipped 9 small DWF files into a DWG file and it was pretty darn sluggish to use but I managed to PLOT to the dwg-to-pdf driver without a crash in R2016 with the same PC specs.
The plot dialog come up fine. The fatal error is after I hit ok to plot. I have tried different copy machines, dwg to pdf and tried using sheet set, to the same printers.
To determined that it was the dwf. I deleted all dwf's and the file plotted fine. Then I added 4 dwf's back in the file and got the crash results. I also recreated the cad file by using a blank dwg and adding back in the cad objects needed. With the dwf's I got the same results.
