I have audited and recovered the file and the one xref to remove any errors.
I have tried plotting in 2015-2016, In Civil 3d and autocad.
I have tried different prinnters and print to pdf.
When I delete the dwf's printing is fine (so, the dwf's are the problem)
What would cause attached dwf's in a file to crash the file when plotting?
John
Civil 3D 2016
The plot dialog come up fine. The fatal error is after I hit ok to plot. I have tried different copy machines, dwg to pdf and tried using sheet set, to the same printers.
To determined that it was the dwf. I deleted all dwf's and the file plotted fine. Then I added 4 dwf's back in the file and got the crash results. I also recreated the cad file by using a blank dwg and adding back in the cad objects needed. With the dwf's I got the same results.
